Old Joe, You can come fairly close to that number with any flat piston, flat head engine by knowing two different engine specs: the stroke and the compression ratio. The stroke is the distance the piston travels from top to bottom dead center. The compression ratio is the relationship between the part of the cylinder the piston travels through versus that part it (hopefully) never enters (the distance at the top you're talking about). Or, compression ratio =swept versus unswept cylinder volume. So in rough popper kinds of numbers if the stroke is 6 inches and the compression ratio is 6:1 then those six inches traveled must be 6/7th's or 85.7 per cent of the total volume, and more or less the total stroke is the difference(in an engine that is neither greatly oversquare or undersquare). So the stroke the piston never reaches must be a tad over 1 inch. The whole this gets a bit more tricky when you try to calculate the same number for your Dodge Hemi head or your high compression Chev pistons with all the little valve clearance machine jobs, and that rectangular hump on the top. But the above should be good enough for government work with a flat head/flat piston. If you want to get more exact about it, there are a few web sites around that have formulas and auto calcs for compression ratios when you deck the block, shave the head, change head gasket thickness, have hemi heads, wedge heads, domed pistons and so on.
