JD won't start!!!
Kelly Shoemaker
04-23-2002 08:35:11
Thanks to all who responded to "Fuel in my oil", We drained the oil and added new, checked the needle in the carb, nothing stuck the float was fine. Put everything back together and went to start mower. NO GO!!! It's acting like it's not getting enough fuel. Made sure the fuel cutoff switch was in the open position. Got the motor to turn a few times and run however it was in very low idle and even adjusting the choke didn't seem to affect the idle and then it would slowly die.
I need your help again... Thanks a bunch in advance...Kelly
Jack Feller
04-23-2002 09:35:17
 Re: JD won't start!!! in reply to Kelly Shoemaker, 04-23-2002 08:35:11
Of course it won't start it's a Deere.
Curious
04-23-2002 09:56:10
 Re: Re: JD won't start!!! in reply to Jack Feller, 04-23-2002 09:35:17
Do you exemplify the typical Tennessee collage student?
