J D H Rear End Lub Question
PUTT - PUTT
12-11-2003 14:57:26
I am about to flush the rear end oil on my "H". Will the drain plug on the bottom of the rear end by the draw bar drain all the oil out of both rear end and trans? There is an oil level plug under the clutch pulley. Is that for both trans & rear end? I presume so. Now there is also a plug a 1/2 inch socket drive will fit into, located on the fly wheel side, behind the fly wheel, near the top of the fly wheel. What is this for? Many thanks for the help with the S/N plate, and now this!!! (1941 model I think)
Clooney
12-11-2003 18:22:51
 Re: J D H Rear End Lub Question in reply to PUTT - PUTT, 12-11-2003 14:57:26
third party image
Putt-Putt, see attached picture for drain plug & fill plug locations..
~I'm not sure what side pipe plug you are talking about but if it is higher than the ones shown & not one of the ones shown it isn't for trans or engine oil adding or removing..
[email protected]
PUTT - PUTT
12-11-2003 19:25:27
 Re: Re: J D H Rear End Lub Question in reply to Clooney , 12-11-2003 18:22:51
Clooney, Thanks for your information. The plug in question is located just behind the 4 stud bolts that are protruding(diagram you sent) It is larger than the oil level check plugs. I was just curious! As you say, it isn't to do with adding,cheching or removing oil. Thanks again
Tractorboy
12-11-2003 17:10:05
Putt Putt if you will order manual # OM-R2011 It contains a lot of useful info on the H and it is not expensive cuz it is the operators book.
PUTT - PUTT
12-11-2003 17:22:57
 Re: Re: J D H Rear End Lub Question in reply to Tractorboy, 12-11-2003 17:10:05
Tractorboy..... Thanks, I must do that. I presume thats a John Deere number.
Tractorboy
12-11-2003 16:55:36
third party image
To flush case,after draining out old oil, replace plug,add 2 gallons of flushing oil. Then jack up rear wheel, start the engine ,shift into gear and engage clutch.Run for a few min. then drain. Add transmission oil of proper wt. 140 wt. for hot weather or 90 for cold weather . The bottom drains the oil and the side plugs tell the ammount . It takes 3 gallons of oil in the transmission.
PUTT - PUTT
12-11-2003 17:16:27
 Re: Re: J D H Rear End Lub Question in reply to Tractorboy, 12-11-2003 16:55:36
The plug on the left {fly wheel side} is much highter than the plug under the clutch pulley plug. What is it for? What year is your "H"? It looks nice. I hope mine looks that good when it is done. It has differant front wheels than mine. Mine has cast front wheels with larger holes. Yours has steel wheels. Are they original?
Gary in TX
12-13-2003 08:29:39
 Re: Re: Re: J D H Rear End Lub Question in reply to PUTT - PUTT, 12-11-2003 17:16:27
The steel wheels were std on the later year models according to what I have read. I have a 41 model tha I am restoring and am looking forward to getting back on it. I have not been able to do much on it this year with hay season going wide open. I hope to have mine going before hay season starts up again. I'm wanting to hear her run, its probably been 20 years since she ran?
Mike M
12-11-2003 20:06:33
I think that plug is for removing the valve lifter shaft.
