Head Lights for a 730
LJS
04-22-2002 23:56:20
Looking for Head Lights for a 730 with fenders, where can I get some and how much should I expect to pay.
Thanks
LJS
G Taylor
04-23-2002 11:06:10
 Re: Head Lights for a 730 in reply to LJS, 04-22-2002 23:56:20
Your local JD dealer has 12V lamps. Available in spot,flood or trapizoid pattern. Price, do you want incandesent, halogen or the new arc lamps? 6V,12V or 24V tractor? For bright lights a separate ground wire back from each light to the battery mid point on the 24/12 system, generator frame or battery "pos" post on a 6V or 12V systems will overcome voltage drop through rusted sheet metal connections. If it's a 6V system make certain the lamp reflector is polished bright & clean, order the largest 6 volt halogen lamp stocked from an electronic supply house. Don't touch the lamp with bare fingers or anything dirty/greasy.
LJS
04-23-2002 20:03:12
 Re: Re: Head Lights for a 730 in reply to G Taylor , 04-23-2002 11:06:10
Looking for original equipment type that came on the 730's with fenders and the early 3010/4010's had them too. They all are 12V
LJS
Duben
04-23-2002 20:12:03
 Re: Re: Re: Head Lights for a 730 in reply to LJS, 04-23-2002 20:03:12
My 730 is a pony start and it's 6 volt. You should be able to find lights from your John Deere dealer or look at the ads in Green Magazine. Think I bought the sealed beams from NAPA.
LJS
04-23-2002 22:51:30
 Re: Re: Re: Re: Head Lights for a 730 in reply to Duben, 04-23-2002 20:12:03
It is electric start, 12V lights 24 V bat.
