630 Spark Plug
Goose Creek Far
12-11-2003 14:45:48
Recently purchased my first "Green" tractor, which is a JD 630 (gas). It need a tune up baddly. What spark plug and size do you recommend? It currently has two different size Champion's in in it. Thanks for your help!
Duane Larson
12-11-2003 19:23:33
 Re: 630 Spark Plug in reply to Goose Creek Farms, 12-11-2003 14:45:48
Goose Creek Farms,
Your 630 originally came with either Champion 8Com, AC 86Com, or AutoLite BT-8 plugs. These translate into Champion D-16 (hottest is D23), AC C86 (hottest is C88L), and AutoLite 386 (hottest is 388). I have given the "hottest" heat range plug in each brand, since if you are not working your tractor hard the hotter plugs will be less likely to foul. The choice is yours - several folks like the AutoLite or AC plug over the Champion.
Carl
12-12-2003 01:14:38
 Re: Re: 630 Spark Plug in reply to Duane Larson, 12-11-2003 19:23:33
Try DENSO 5000. Had real good luck with them.
