JD 80 pony motor
Shawn
04-22-2002 18:32:44
Having a problem with the pony motor not starting.I crank the motor and it won't start.if you take and ground one of the plug wires to the frame you get a backfire through the air breather & then it fires rite up. Have a fully charged battery..Any ideas?...Thanks in advance...
G Taylor
04-22-2002 19:10:28
 Re: JD 80 pony motor in reply to Shawn, 04-22-2002 18:32:44
New coil(s) are required. Pup ignitions left on without the engine running will rapidly short together or burn open the coil(s) if the points are closed.
