What have I got?
Austin
04-22-2002 18:19:08
I ordered a new set of valves for my 38 B and when they came the exhaut valves were too small .Double checked part # and was correct I cannot say that this head is the original head because on all my other 5 unstyled b the heads are flat across the face .This head has two domes that face each piston. the valve sizes are 7-16 in diameter app 7 inches long and 1.720 across the face. some one has been into this head before because one of the guides has been welded to thi heas .Any suggestions or advice short of hunting a new head?
BobTGS
04-23-2002 07:38:27
 Re: What have I got? in reply to Austin, 04-22-2002 18:19:08
Hello Auston, as Rusty said ,it sounds like you have a Heisler head.It's probably # HB357.I have new valves in stock that will work ,for around $20.00.If you are interested call my shop at 1-716-542-3175 , 9am-8pmEST.Bob,from Triple G Service.
rusty
04-23-2002 07:08:14
You mentioned that the head had two domes facing the piston. To me it sounds like you have an unstyled heisler head which will have slightly bigger valves in it. Does the head have a part # below where the valve cover bolts on, that your other heads do not have?
BMAN
04-22-2002 20:12:31
I would guess you have the wrong head. It should have part # B357R. That's the correct head for a 1935-1938 B JD. A 1939-40 B uses a head with part # B1306R
