J D 7000 corn planter
Tom
04-22-2002 12:18:49
I recently purchased a 4-row- 7000. The serial number tag is gone. Does anyone have any ideas on how to identify? Hard to buy parts without the number or at least the year.
Thank You
Mike Aylward
04-22-2002 17:04:30
 Re: J D 7000 corn planter in reply to Tom, 04-22-2002 12:18:49
Tom, there aren't a lot of differences between all the 7000 four-row planters that require you to know your serial number. The first year (1974) used a different bearing on the marker disks, similar to the closing wheel bearings. The later planters used steel, single pitch sprockets on the seed drive transmission instead of the older cast double pitch sprockets, but many have been updated. This was done somewhere around the '80-'81 time frame. They all used double pitch chain. The closing wheel pivots were enlarged after a few years (approximately '79 or '80), and the backing plates for the pickup units were changed several times over the years. The parts book mentions a serial number break at 64,400 (I think) and that is approximately the 1979 model year. As far as the back plates go, odds are yours have been replaced sometime in the planter's life to the latest style so you will use the latest brushes. Most parts are common to all the four row planters. A parts book would be a good thing to pick up. I have a 7000 planter and used to be a parts manager at a John Deere dealership so I have bought and sold a lot of 7000 parts. If you have any other questions feel free to email me. Mike
JD 4000
04-22-2002 18:50:55
 Re: Re: J D 7000 corn planter in reply to Mike Aylward, 04-22-2002 17:04:30
HI mike..
do you know about the JD planter #80? I have a 4 row like that. been to JD get parts. do you know anything about this planter what year they start building them and stop..
steve
Mike Aylward
04-22-2002 20:59:16
 Re: Re: Re: J D 7000 corn planter in reply to JD 4000, 04-22-2002 18:50:55
Steve, I know the 80 was a unit planter that was patterned off the row units of the 1200 series drawn planters. Your dealer should be able to get most any part you need. There are still several of those style of planters around. Hope this helps. Mike
