Clooney,you the man!
Jack
04-22-2002 04:56:34
The 53 G charges great after your wireing diagram helped me put it together.My belt twisted though.I will get one today.What causes that?Thanks greatly and later.Jack(TN).
Clooney
04-22-2002 17:49:49
 Re: Clooney,you the man! in reply to Jack, 04-22-2002 04:56:34
Jack, glad you are up & charging again.
~Your belt could be twisted due to the problems Chuck explained, or you could have a pulley mis-alignment between the generator & fan shaft pulley. Hold a straight edge along the sides of both pulleys & see if one pulley aligns with the other pulley...
ChuckW
04-22-2002 05:03:58
have noticed several people posting and you are absolutely correct about Clooney. He is on of the most knowledgable persons I've seen. You belt probably twisted due to a stretched spot and you may have tightened too much. Use a new belt and don't tighten a lot till it is broke in. I always like the solid belts.
