ADDITIONAL PAINT COMMENTS FROM BELOW
MIKE HANLEY
12-11-2003 08:23:19
Had some additional comments in addition to the comments I made below. Besides trying to put a gloss on the stuff that wasn't there when it left the factory I can't stress enought about what you do for touch up. Go over to the photo section, deleat DEERE and type in my name. All 4 our our tractors are pictured. The 730D with the wide front is the way we got it 8 years ago. Yes that needs a paint job. Maybe next year. Now look at the 630 with the loader. I did that in 1984 or 1985 with classic green right out of the can without hardner. Not bad looking for a daily in use working chore tractor with an almost 20 year old paint job. I did that trator in 1984 or 1985 useing classic green right out of the can without a hardner. The 630 has new paint on it this summer only because the battery blew up and discolored the whole back the tractor. I did the tractor and the loader again with classic green rigth out of the can without hardner. I ran out of weather and the hood is being done atv a body shop. AND YEA I PAINT RIGTH OUTSIDE. Now look at the 730D with the roll-a-matic I did that one two summers a go again with classic green right out of the can without a hardner. Now lets see,,, The 730 with the new paint is sitting down at WESTBY totaly tore down getting the block bored. What will I do next spring? Touch it up with classic green right out of the can. I have the float ride seat in the basement anfter gettint the new rubbers and bushing put in and I replaced the tin at the front and the back of the frame with 1/8" steel. This afternoon the frame will get painted with classic green right out of the spray can and friday I'll take it to Westby and put it on the tractor. No fancy mixing trying to get the paint to match. When the 630 comes home it will spend the winter plowing snow and feeding cattle. Both the 730 and the 630 will hitt the fields and after 1st crop hay I will touch up the paint and drive them to WESTBY and have them at the COULEE REGION show. Both the 630 and the 730D had the hoods painted while off the tractors. Now put the hoods on and what about the hood bolts? Classis green rigth out of the spray can and the yellow rigth out of the spray can and it's a perfect match. I sure not going to spent time mixing paint, getting the gun ready and then cleaning up everything just for a small touch up. Grab the spray can. And what if you didn't quite mix up enought paint to finish the touch up? Mix all over again? Or if you mixed up too much and there you sit with hardner it the paint. Look for something esle to paint? I have better things to do.
Mike M
12-11-2003 20:20:55
 Re: ADDITIONAL PAINT COMMENTS FROM BELOW in reply to MIKE HANLEY, 12-11-2003 08:23:19
I too have always used whatever paint mother dear sells. JD has played with the colors and formulas a lot over the years since I started restoring them in 1976.I have always been pleased with the results and the price. I too also paint outside tried indoors once and got to much dust. Glad to see I'm not alone in this world of over priced fancy paint.
Garland
12-11-2003 18:50:04
Mike I'd just like to amen your comments.I;m presently painting a John Deere 4000 I had a guy help me with the hood,I have trouble getting all the dings out,he wanted me to use some of these facey named paints,hardner,clear coat and what have you,I told him no thank you,No.1 I'm afraid of the hardener,heard some might scary stories.and I think the acrlics chip to bad further more this tractor is binging set up to pull a hay roller and batwing,and the classic green doesn't chip as bad as tha that fancy stuff my two cents worth. Gman
Henry J
12-11-2003 08:55:05
Mike
It sounds like you like your paint like I like my beer "right out of the can." I hope it wasn't me that lit your fire. Sure did not mean to.
Mike M
12-11-2003 20:27:35
 Re: Re: ADDITIONAL PAINT COMMENTS FROM BELOW in reply to Henry J, 12-11-2003 08:55:05
Thats probably how the factory painted. At least that would explain all of the runs .
MIKE HANLEY
12-11-2003 15:32:46
No just being down to earth. Ok the tractor now has a fancy new paint job. Well we must show it off. We could get a climite controled glass cage and hve people come,,,OR we can take it to a show. So lets back up the gooseneck and load 'er up. HAY take off those boots. Dom't you dare mare the platform!!!! And better get to the house and change into the sunday best. No way are you getting on that tractor with your grubbys on. Now your loaded. Where are you going to put the tie down chains without maring the paint. Lets bolt some chain grab hooks unter the belly and on the drawbar. Talk about the pimple on the end of your nose the morning of the prom. What are we going to do with the hooks. Leave them on as is leave them on and paint them. Or take them off when we get to the show. your options here are smucked paint on the hooks, smucked paint on the frame after you take the hooks off, or have the silver hooks hanging from it's belly. Just like the pimple, chances are no ne will say anything, BUT YOU KNOW IT'S THERE and when you step back and look at your tractor after it's in the line, all you are going to see is the hooks. But thats after you get to the show. Lets get down the road. Your tooling along at 60 and here comes a string of gravel trucks doing 60 coming from the other way LOADED WITH GRAVEL. OUCH on the paint. Now two summers have pasted and the tracxtor is in the shed in the winter. It's only been run loading and unloading so your fluids are OK, right? Or do you wake up at night thinking how much condensation is in your fluids sitting in that tin shed for 2 winters. So the third spring you bite the bullet and change fluids. It's a 20 or 30 series with power steering and that nose cone has to come off. There we stand with wrenchs in hand wondering how we are going to get the nose cone off and all those covers and plugs off without smucking the paint. WHAT WILL WE DO,,,WHAT WILL WE DO!!! Well just do it because it's classic green right out of the can and when your done you just grap the spray paint can. No just down to earth. Same way with our horses. We're out riding in the brush checking cattle, take the saddels off load them up go to a parade. Comb them out and throw the saddles back on and it's parade time. Just ahead of us is the lady with the horse that never gets out of the 10 X 10 box stall, that had a full bath and it's hoves painted and it's hide all oiled up. Ours are just as pretty and when we get home the door on the trailer comes open they go over to the dirt and have a good roll before they take off to the ridge at full run. No just down to earth.
Mark
12-11-2003 18:50:20
 Re: Re: Re: ADDITIONAL PAINT COMMENTS FROM BELOW in reply to MIKE HANLEY, 12-11-2003 15:32:46
AMEN, I paint for hire when not farming. Fortunately 95% of my customers are realists. I grew up on these fine machines and use something newer to earn a living but I do not want the paint to stop me from from using these machines around the farm or at an antique plowing day. To each his own but trailer queens become a bit vain even if I did paint some.
Steve - IN
12-11-2003 18:33:36
third party image
You got it right for the kinds of tractors we both own. If you're going to use the tractor, don't go overboard on the finish.
The main problem with the tractor that has the bucks and time in the new paint job is that it makes you sick to see what it's become after a few months in the field. Here's my old H that I redid last winter. Looks passablev - but not for long. The smart thing I did was to take a picture of each part of it when it was done this Spring. After all summer working, come December, it doesn't look quite this pretty anymore.
Then again, my red H and my JD 60 and my JD 1020 are still fairly plentiful items. If I had some ultra rare piece that really deserved to be a shed /trailer queen -- I guess I'd go to the 9th degree with the finish and never take it near a field. We had an Arabian filly years ago who won a wall full of blue ribbons. She was a stall queen and knew it (think she loved it, too). Eventually she became a brood mare so she could pass on those wonderful genes she possessed. Such is life for men and horses. But for tractors, you can argue that like a fine wine; the older they get they more rare and valuable they get. Act accordingly; to everything there is a season.
