Hi,Trying to get a D running for parade on Saturday, and I have a couple of questions for an expert (or even half an expert) Last time the tractor ran, it experienced fuel trouble. I removed the carb, chem dipped it, blew out all the ports, and ordered a kit to be here tomorrow am. Fuel lines, bowl, and tank were cleaned out. Plan on installing an in-line fuel filter. The last carb I saw with so many adjustment screws on it was on my 1979 Honda Accord! I hope that they are not all "adjustment" screws. One is actually labeled "idle adjusment" so I am halfway there. Anyone have any tips on setting the carb correctly after a rebuild? or will the kit (from JD dealer) have this info? One other question... this tractor has been sitting outside, so the transmission probably has water at the bottom and will have to be drained. I couldn't find a fill level plug (it was dark, dirty, and all I had was a drop light and not a lot of patience at that time of night). Is there a fill level plug for the transmission case, or how much oil do I put in? Where is the fill level plug? I thought for sure it would be on the right or left side, but I sure couldn't see it... unless it is a recessed plug not a regular square plug... hmmmmm. Any help will be terrific. I have a lot of great memories driving this tractor several years ago, and look forward to starting it up again tomorrow. What a great sound this tractor makes! Oh yeah... I think this is a "newer" D. I can get the SN if it's important. -Sue
