3020 gas tractor has engine problems
JD70Jim
04-17-2002 11:46:19
This is a 1967 gas 3020 row crop tractor. Currantly, it is extremely hard to start, and when started the engine lacks power and runs very rough. My guess is that I have a possible twisted /cracked/broken crankshaft. This tractor had a top end overhaul two years ago (<150 hours) but the bottom end wasn't touched. After finally getting the tractor to run, there is a funny, growling noise in the engine, and when in gear, the tractor wobbles from side to side as if something was unbalanced. It backfires frequently. Any suggestions?
John
04-17-2002 12:27:17
 Re: 3020 gas tractor has engine problems in reply to JD70Jim, 04-17-2002 11:46:19
My first guess without research is a broken balancing shaft. Should be one on eitherside of the crankshaft driven by gears in the front cover. Drop the oil pan and take a look. Grab a hold of each shaft at the rear of the block with some channelocks and see ifn its in one or two pieces. That would solve the wobble but doesnt account for that lack of power or hard starting. Probably run a compression check and see what you get.
