John Deere 2010 PTO Gear Oil Question
Daniel T. Maxey
04-16-2002 20:50:04
I have what I believe to be a Gasoline 1962 John Deere 2010. Where can I drain, check, and fill my PTO cavity.
What is best, Gear Oil or Tractor Hydraulic Oil? I would deeply appreciate any help I could get!
Steve Vandagriff
04-17-2002 13:29:08
 Re: John Deere 2010 PTO Gear Oil Question in reply to Daniel T. Maxey, 04-16-2002 20:50:04
According to the John Deere repair manual for the 2010, the powershaft housing must be removed from the tractor and drained through the filler hole. The filler hole is located on the side of the powershaft housing and is a pipe plug. The recommended oil is John Deere 303 oil. I haven't found a drain plug in the manual anywhere. The oil level is to the level of the filler plug.
