50 A generator
Larry T
12-10-2003 21:12:34
Trying to figure out if my generator is working correctly. I'm trying to use the suggestions other people have already suggested (Clooney). I cannot find any markings on the generator to indicate the "F" or "A" post. Whis is which?(they seem to be the same size) The regulator has three parallel attachments and one under the regulator. Are these the "Bat", "Arm" and "Gen" terminals? I need some help identifying these posts. I also discovered the polarity is reversed but I understand that doesn't make any difference.
With the tractor off and the lights turned on, the ammeter discharges just slightly. With the tractor running it charges alittle but when the lights are turned on I get a slight discharge.
Would appreciate any help.
Clooney
12-11-2003 09:27:38
 Re: 50 A generator in reply to Larry T, 12-10-2003 21:12:34
Larry, seeing as you don't know what generator you have & can't tell if the post sizes are different you won't be able to properly polarize or even check it out..
~You can't even in good conscience jump wires at the regulator to polarize it as you aren't sure the wires are hooked up correctly or what generator you have..
~There isn't even a guarantee that you have the correct generator or even the correct type generator.. If you have a Ford type instead of the original Delco generator even using an ohmmeter won't tell you what post is what as the field is internally grounded & not hooked to the armature post on a Ford type..
~I guess the best place to start is to clean the generator housing & look for numbers or even a Delco stamping, also look for small stamped letters next to the 2 posts [like A or F].. Then try removing a stud nut from one post & trying it on the other post [maybe that will help to determine stud size].. There isn't a great difference in stud size BUT most Delco generators do have a different size [A] & [F] post.. If they are really exactly the same size you have an oddball [maybe someone rebuilt it using 2 studs of the same size]...
~I Guess the best way to try & determine what post is the armature is to first MARK for position, then remove both wires going to the generator posts.. Then use a test light & probe the terminals on the regulator & find the one that ALWAYS has battery power to it. Then remove the generator belt, then use a jumper wire & run battery power from the regulator's [powered battery terminal] to one then the other generator posts.. If one makes the generator motor you have found the [A] post...[mark it as such]
~If the generator motors by powering up one of the generator posts, leave it spinning under power then try grounding the other post,, If the generator slows down you probably have the correct type Delco generator & it is more than likely working good.. That post would be the [F] post [mark it as such].
~If the generator doesn't motor by powering either post you probably have a bad generator.. If it motors & doesn't slow by grounding the non [A] post you either have a bad field or you have a Ford type generator [post back or E-Mail if the generator won't motor or slow down].
~If the generator motors & slows down in the above test, mark the post that makes it spin by powering it as [A] & mark the post that slows it down by grounding as [F]..
~You won't need to polarize it if it spins & slows down per above as that would have already polarized it.
~If the generator seems to spin up under power & slows down with the [F] post grounded make sure the regulator is properly grounded..
~While looking at the generator, see where the wires go from the regulator to the generator.. If you remove the regulator's screws & clips that hold the wires on the terminals there should be some small stamped letters on the tops or bottoms of the terminals like [gen],,, [fld],,, [bat],,, the wire that comes out of the bottom of the regulator is more than likely the [gen] terminal & would go the generator's [A] post.. The [F] terminal goes to the generator's [F] post, the [bat] terminal should be powered & run to the ammeter's non battery side & the [L] terminal [if you have one] should run to the light or ignition switch].. If the above doesn't seem to fit what you have, post back or E-Mail
~Do the above & see what you can determine.. I am reluctant to give you a full generator & charging system test sequence until I know for sure what generator you have & if it is wired correctly..
~The above is a lot to understand if you don't work with charging systems regularly so I purposely kept it short & hopefully understandable...
~It helps to print this out & take it to the tractor with you..
~Post back or E-Mail with any questions you might have & we'll get you up & charging..
[email protected]
Larry T
12-12-2003 10:20:16
 Re: Re: 50 A generator in reply to Clooney , 12-11-2003 09:27:38
The generator is a Delco and I removed it to clean all the connections so I was able to determine "A" and "F" posts. Also on the VR where the "F","BAT" and "L"(load???) connectors were. After reinstalling the generator it performed the same. (slight charge running) Will do some more tests when it warms-up alittle. (non heated building) Thanks for the help.
John T
12-12-2003 12:50:20
 Re: Re: Re: 50 A generator in reply to Larry T, 12-12-2003 10:20:16
Youre welcome Larry, do the tests I posted below to determine if its more a Generator or Voltage Regulator problem and post back or e mail.
John T
John T (More Info)
12-11-2003 08:30:24
Larry, My earlier post addressed how to find which Voltage Regulator terminal is what and heres a bit more info on determining which generator post is ARM and which one is Field.
If you have a fairly accurate ohm meter (assuming all is good inside and its a standard 2 brush generator) FIRST REMOVE ALL WIRES TO THE GENERATOR. Connect one lead to the steel case of the generator and measure the resistance between it and the 2 external connection posts.
The ARM post will be the one that has LESS resistance than the Field post. Thats so because the Field post first goes through both field windings and then connects internally to the Armature post which leads current to the first brush, in and out the armature windings, and then to ground via the grounded brush.
Therefore, the ARM post has less resistance to case ground than the Field post cuz it (FLD) has to go through the additional field winding resistances before getting to the ARM.
Post with less resistance to case = Armature. Post with additional resistance = Field.
Post back or e mail jmn50 any questions.
John T
Larry T
12-12-2003 10:27:55
 Re: Re: 50 A generator in reply to John T (More Info), 12-11-2003 08:30:24
I did try your resistance test and it did work. Still working on the problem when temperatures get better. Thanks for the help.
John T (Gen/VR Wiring)
12-11-2003 07:11:12
Larry, I can help you get going once we get all the info we need. I will first describe for you the Generator and Voltage Regulator wiring,,,,, next how to determine which terminals are which as you asked,,,,, and then finally how to troubleshot if its a Voltage Regulator or a Generator problem. First, make sure the belt is good and tight and not glazed and the Generator and Voltage Regulator are well grounded and all connections clean and tight.
Before we begin identifying VR and Generator terminals as you asked help on, have you polarized???? POLARIZE by simply momentarily flash jump a wire from the VR's BAT terminal over to the VR's ARM terminal (or ARM post on the Generator) and you should get a small spark. The VR's BAT terminal is the one that has a wire to it (from ammeter) that is ALWAYS HOT (use a test lamp or voltmeter to determine). If youre unsure what any VR terminals are and/or its hard to get to the ARM terminal on the VR, you could simpy flash jump a hot with battery voltage wire to the ARM post on the Generator to polarize BUT CAUTION DO NOT jump to the FIELD post on the Generator. A test lamp on the wires to the VR tractor not running will readily indicate what wire is always hot, and thats the one to the VR's BAT terminal and one that could be used to polarize the Generators ARM but AGAIN CAUTIONN NOT to the Field post.
NEXT, if your Voltage Regulator has 3 terminals in a row on top PLUS one by itslef off the bottom, its likely a 4 wire Voltage Regulator (BAT FIELD LOAD ARM) and on many of those, the one off the bottom or on a side all by itslef is the ARM terminal. THEREFORE, if a wire off its bottom goes to the generator now, thats probably the ARMATURE post on the Generator, leaving the other the FIELD post which also is wire to the VR, but probably one of the 3 similar terminals in a row.
1) Lets see if youre wired up right and identify the VR terminals.
*************VOLTAGE REGULATOR WIRING*********** On a 4 wire VR (if thats what you have), the 3 terminals in a row are BAT FLD and LOAD and the one on bototm is "probably and often" ARM.
a) The BAT terminal is the one that is wired up the the load (not to battery) side of your ammeter. Use a test lamp or a volt meter and the wire leading to the VR terminal that is always hot (i.e. that wire if disconnected from VR) should be the BAT terminal lead. With the tractor not running, the FLD and ARM terminals should NOT show battery voltage.
b) The FLD terminal is one wired to one of the posts on your Generator. (often the smaller of 2 posts) With the tractor not running, it should NOT show battery voltage.
c) The LOAD (L) terminal (if its used on your set up) would be wired up to the ignition and lights switch battery input terminal. NOTE it may be the case that the LOAD terminal on your VR was not used. Regardless if it came with a 3 or 4 wire VR, many got changed over the years.
QUESTIONS Is there a wire on all 4 of your VR terminals????? ????? Is there a wire on a VR terminal that goes up to your switches input???? If all 4 wires were used and one leads to the ammeter (BAT terminal, always hot) and one to the switches input (LOAD terminal), then you have a proper wired 4 wire VR.
d) The ARM on the VR (often one on bottom or itself on 1 side) should be to the ARM post on your generator.
IF ITS A PROPER WIRED 4 WIRE VR AND LIKE MANY BRANDS, THE WIRE OFF THE BOTOTM OR SIDE BY ITSLEF IS TO THE GENERATORS ARMATURE.
The above should help identify the VR and Generator terminals. If the ammeter swings to discharge tractor not running and charges some (even if weak) your gen and VR are probably wired correct. The wire that is ALWAYS HOT should be to the VR's BAT terminal and if it were removed, none of the other VR or Generator terminals would any longer show voltage.
**************GENERATOR/VR TROUBLESHOOTING*******
To save a ton of time, Im going to cut and paste my standard generic Generator/VR troubleshooting tips below. Some may be a repeat of the above.
1) First, be sure the belt is good and tight and the generator has a good ground to the tractors frame and that the VR has a good ground to the generator. Many problems are caused by a bad ground to the generator or the VR is not well grounded (usually to the gens case). You might run a wire direct from the batterys grounded terminal down to the gen and VR and and connect it to see if thats the problem.
2) There has to be hot full battery voltage present on the VR's BAT terminal so its output can get to and charge the battery. (Use a test lamp or voltmeter to insure that before you go on) The HOT path to get there, is from the battery itself or off the starter post, to and through the ammeter, then down to BAT on the VR.
3) Now if the grounds are good and the VR's BAT terminal is hot, you can finally test the gen and VR to determine which or both are bad. With the tractor running, use a jumper wire and connect the F post out of the generator (smaller of the 2 gen posts) to the generators steel frame ground, and if the ammeter then shows better charge, you either have a bad VR or a bad/broken wire connection between the generators F post and the F terminal on the VR.
4) If she still doesnt show charge, leave the F grounded, and then momentarily connect the BAT and ARM (or GEN) on the VR (or connect the BAT VR terminal down to the ARM post on the generator if the VR's ARM terminal is hard to get to) together to see if it shows more charge. If she charges then, you have a bad cutout relay inside the VR. If it shows charge only if you connect the VR's BAT terminal direct down to the gens ARM post, the wire is bad (open) between the gens ARM post and the VR's ARM terminal.
5) With the F still grounded and the GEN or ARM on the VR connected to the BAT terminal and if the Gen and VR have good grounds and assuming the BAT terminal is connected to the battery via the ammeter and she still dont charge, its probably a bad generator, cuz you have essentially by passed any bad VR with the tests above.
6) You can also motor test the gen by removing its belt and all its wiring (protect all the wiring so it doesnt short out) and jump wiring the ungrounded bat terminal (i.e. - on a + ground system) to the generators ARM post (larger of 2) and the generator should turn like a motor. A source of such battery power could be the wire from the VR's BAT terminal, as it leads to the battery via the ammeter. If it runs when you do that, then ground out the generators F post and she should slow down slightly. If not, the gens field may be bad. If the gen turns when you apply battery voltage (from the BAT lead or elsewhere) and slows slightly if you ground out the F post, it should generate power fine.
7) For the generator to charge the battery, there has to be a connection between the BAT terminal on the VR to the battery (usually via the ammeter) and test that by using a test light or DC voltmeter and battery voltage should be present on that post ALL THE TIME. If the gens power doesnt reach the battery, it cant ever charge it, and the path is out the ARM post on the Gen, to the GEN or ARM terminal on the VR, through the VR's cut out relay, out to the BAT terminal on the VR, through the ammeter, then to the battery.
8) If she dont charge despite all that and the tests show the gen is bad and NOT the VR because you by passed BOTH the Field and Cutout Relay per the tests above, and the rest of the wiring is good and the gen and VR are grounded properly, heres a few gen troubleshooting tips:
a) Many problems are the brush hold down spring assemblys are rusted and corroded so the brushes are not held down tight against the commutator. Use a wire brush and WD 40 and air etc to clean and free up the hold down spring assemblys so the brushes are held tightly down. If the brushes are not worn down too low and held down tight and she still wont charge, you may have an open field winding or a bad armature or a commutator problem. Post back if you want to repair the generator and maybe I can provide more tips.
I hope this answers your question on how to identify VR and Gen terminals and how to tell if the problem is a VR or a Generator problem. Post back or e mail any more questiosn to [email protected] and I will try my best to help you. Hopefully if I missed anythign others can offer additional tips and opinions and you might want to print and save this for reference at your shop. If you want a B Wirign Diagram, post back or e mail me your address. I can also tell you how to tell which generator post is which from the way the generator is wired internally if it comes to that and you dont get it going per the above.
Good luck n God Bless ya Larry.
John T Nordhoff in Indiana, [email protected]
Larry T
12-12-2003 10:22:39
 Re: Re: 50 A generator in reply to John T (Gen/VR Wiring), 12-11-2003 07:11:12
Like I told Clooney, I've determined all the connections and now I'm waiting til it warms up to do some of the tests you guys suggested. Thanks for the help.
