JD 50 Radiator Overflows
Fred McIntire
04-16-2002 07:00:09
I just bought my first tractor. It is a JD 50. I'm not sure of the year yet. I have to check the serial numbers.
The problem I'm having is the coolant runs out of the overflow on the radiator when the tractor is running. It does not seem to overheat. The temperature gauge reads a steady 140 operating temperature. Any idea what could be going on here. The neighbor guy I bought the tractor off of said he put some stop leak in it to repair a radiator leak. I'm wondering if the stop leak has plugged up the radiator.
This is a really neat old tractor. It had been in the same family since it was new. It's all original except the addition of a 3-point hitch.
I always thought I'd own a Farmall as my first tractor; however, this JD is a real beauty. Thanks for your help.
Kerry
04-16-2002 19:56:23
 Re: JD 50 Radiator Overflows in reply to Fred McIntire, 04-16-2002 07:00:09
My 1955 JD 50LP overflows all the time until it gets an inch or 2 down, then it's fine. The radiator is plenty big, just leave it a little below the neck and it should be ok unless you really do have a leak somewhere. Mine rarely even gets up to 170 unless I'm pulling it pretty hard, just puttering around it takes it forever just to warm up and never really gets up to temp.
Kerry
Roy
04-16-2002 17:05:54
Had a 50 that that was fine at idle give it some throttle and the radiator would overflow. Radiator was clogged.
Frank-in-Tallahassee
04-16-2002 08:30:16
Fred:
Those radiators have quite a sizable tank area in the top above the core to account for the expansion of the coolant. Could be that it is overfilled, and it 's just burping it out as it warms up. Maybe when it gets to a level that it has enough room to expand without over flowing it will stop.
It could be exhaust gases leaking into the coolant side though a crack or headgasket leak, but if you don't see the coolant dropping or going into the oil, I'd say check how far you are filling it.
Does it gush out ? A head gasket can cause a belch of gas to rise pretty fast and blurp out a lot of coolant.
Let us know what other symptoms there might be.
70D // 855
