Will a 720D pull 4-16 plow in hilly sand..?
Barry
04-15-2002 11:03:08
I'm thinking about buying a oliver 4-16 plow for my 720D but I don't know if it will pull it without putting to much stress on the engine and chassis...anyone ever pulled one with your 720D..Thanks
Doc
04-15-2002 15:56:22
 Re: Will a 720D pull 4-16 plow in hilly sand..? in reply to Barry, 04-15-2002 11:03:08
Barry,
Used to use a 730D (same engine) with a 555 4-16 in good heavy loam, up and down hills. If your 720 is running good it should be no problem. Dad used to have the clutch set pretty tight for fall plowing... It would pull the 4-16s really well in fourth. Used to run at 200 degrees all day without a problem.
Have fun!
Doc
Will P
04-15-2002 15:17:13
Was just at a plowing with my B and there was a 730D pulling around a 4 bottom plow. Don't know how wide. But he had no problem lapping me, with just my B pulling a 2-14" plow. This is in a corn field in Wisconsin. I see no problem with your 720D pulling the 4-16"
Will P
DON
04-15-2002 13:05:50
WE pulled 5-16's with a 730 in hills and clay. You should be able to pull 4-16 ok. Our 730D had 3rd gear for plow gear, a transmission with 4th gear for plow gear would be better. Don
