JD Unstyled A
Matt from IN
04-15-2002 08:10:46
I would like to put lights on my "A". Anyone have a clue where to Start?
jdman(MO)
04-15-2002 16:27:23
 Re: JD Unstyled A in reply to Matt from IN, 04-15-2002 08:10:46
I have thought about this on my 38 A. You probably already have a fan with belt pulley on it. You have to find a place to locate the battery, then get a late model A 12v generator and regulator. Then 12 volts sealed beam lights and make your own brackets. I think a small platform behind the seat, and since you are not going to use a starter, a small 12 volt battery would be ok. You are not going to be original, but its your tractor. Also go to a salvage yard and get the generator brackets off a later model tractor. Russ
