Dissasembly questions
Dave
04-15-2002 07:59:15
third party image
I am slowly taking apart my JD1010, as I believe I broke the ring gear or stripped the pinion. I have the parts manual and shop manual, but they arent very good on details. I am trying to get a look at the ring gear area to do an inspection, and have the seat and fenders off. I just pulled the trans shifter cover off to look inside, the trans gears all look ok but I couldnt see inside to the ring gear area. Can I remove the large hydraulic assy that is under the seat in one piece to get a look inside to the ring gear? Here is a picture of the part I am talking about. Can I just unbolt it and pull it up and off?
DON
04-15-2002 13:08:44
 Re: dissasembly questions in reply to Dave, 04-15-2002 07:59:15
Yes, remove the rockshaft housing and you will see the differential. Don
Dave
04-15-2002 13:27:44
 Re: Re: dissasembly questions in reply to DON, 04-15-2002 13:08:44
third party image
Looks like I found the problem..I went ahead and looked at some other stuff before pulling the rock shaft housing, and when I pulled the cover for the left side axle drive gear, I found a gear tooth laying inside. I pulled the final drive off, and found the pinion gear missing 4 teeth, all broken off and laying in the housing. Main large bull gear looks ok. Looks like I got lucky, I would think the ring and pinion are ok. Since I dont believe this tractor has a locking rear,this damage would kill both drive wheels from what I can figure, all power would of been put to the easier wheel to turn, or in this case the broken gear, so the tractor wouldnt move. Sound right?
Dave..NO such luck, more damage found
04-15-2002 14:45:43
 Re: Re: Re: dissasembly questions in reply to Dave, 04-15-2002 13:27:44
Well I was hoping the drive gear was the only damage, but things didnt make sense..looked inside the housing with a flashlight and saw that the ring/pinion is also trashed. I am not having a good day!
mike
04-15-2002 18:40:38
 Re: Re: Re: Re: dissasembly questions in reply to Dave..NO such luck, more damage found, 04-15-2002 14:45:43
looks like you need a good dentist.
