Need an opinion
AGR538
04-14-2002 19:58:37
I have located a '61 2010 gas for $2,700. It is worn out but sheet metal is good and everything works from what I could tell. Is the 2010 a good tractor? Is that a decent price? How hard is it to install hydraulic outlets? Also, I need to know how the three-point hitch levers worked. He said the three levers on the console were disconnected and a lever under the seat operates the hitch. Thanks in advance for the advice.
ROS
04-16-2002 18:41:52
 Re: Need an opinion in reply to AGR538, 04-14-2002 19:58:37
This tractor is a deere nightmare, follow these wise suggestions from this board. Happy tractor hunting, get a 2020.
DON
04-15-2002 13:17:53
The 2010 was a good tractor when every thing worked,However----- they were a real bi--- to work on , they always leaked , the hyd. system was junk,the motor was a pretty good engine for the most part. Now you cant get parts for them . My advice is to run like H---- the other way, buy a 2020 and you will be much happier. Don
Bart
04-14-2002 21:38:40
Gpower is right. 2010 is the worst tractor JD ever made.
Bart
Gpower
04-14-2002 21:03:00
Leave it where it sits. All you will do is work on it. Save your money and buy a little more tractor and save yourself from pulling out your hair.
Gpower
AGR538
04-15-2002 06:36:53
 Re: Re: Need an opinion in reply to Gpower, 04-14-2002 21:03:00
Thanks guys. I guess you have saved me some money and headache.
