3010 throttle adjustment
wolfy
04-14-2002 17:55:51
How do you adjust the hand throttle friction on a 3010? Have to hold lever all day or it slowly backs off to low rpm. I've adjusted the friction on a D-17 but I'm unable to find the adjustment on the deere. Thanks
Mike
04-14-2002 19:21:41
 Re: 3010 throttle adjustment in reply to wolfy, 04-14-2002 17:55:51
I had the same problem---The little friction pad was wore out on mine so I had to remove the steering wheel and pull the steering shaft out to replace the pad.
twopop
04-14-2002 18:51:59
take the dash cover off,stand at the left side of the tractor and look where the steering column goes into the steering gear.you should see a 1/4 inch bolt which adjusts the friction disc.you may need to open the access door under the steering column.
Matt
04-14-2002 18:56:52
 Re: Re: 3010 throttle adjustment in reply to twopop, 04-14-2002 18:51:59
Mine did the same thing, tightend up that bolt and it made a world of a differance.
wolfy
04-19-2002 17:37:12
 Re: Re: Re: 3010 throttle adjustment in reply to Matt, 04-14-2002 18:56:52
Thanks for the info-tried twopop's suggestion was able to tighten bolt some; seems to have come up to limit. Thanks again.Wolfy.
