Finish mower on a John Deere M????
Pat Cox
04-14-2002 04:22:53
I recently purchased a John Deere M, to use with a grooming mower. I installed a Worksaver HK-201 three-point hitch adapter kit. The lift arms have a fixed 26� pull pin spacing. The problem I have is that the Land Pride finishing mower I wanted to buy won�t fit that pin spacing. Neither would a Woods. In fact, none of the three point implements on the dealer�s lot would fit that spacing.
Does anyone use a John Deere M with the Worksaver HK-201 three-point hitch with a grooming mower? If so, what make and model? Has anyone found a boom pole and scraper blade that would work with the 26� pin spacing?
Thanks in advance,
Pat
jdman(MO)
04-14-2002 06:50:04
 Re: Finish mower on a John Deere M???? in reply to Pat Cox, 04-14-2002 04:22:53
Sent you E-mail that should solve your problem. Russ
