Non-Foulers for Spark Plugs?
AWB
04-13-2002 20:47:10
Am Having severe spark plug fouling problems with my John Deere LA. Does any one out there have any experience with Non-Foulers that attach to the spark plugs?????
CPeeter
04-14-2002 05:49:53
 Re: Non-Foulers for Spark Plugs? in reply to AWB, 04-13-2002 20:47:10
I posted this several times. Yes, they do work for me on my tractors. I believe that there is an unbalance in the air flow in the two cyclinder design caused by the uneven firing (180� & 540�). I think that this contributes to the fouling problem. I have had my 40 for over 30 years and it has always run rich on one cyclinder and my 420 does the same. Your "L" is a similar design. "I use antifoulers on both my 40 and 420. They really work great. These are small extensions that go in the spark plug hole and then the spark plug goes into the extension. It creates a little chamber that is not subject to getting the oil from the cylinder. Not only does it prevent fouling, but the tractors start and run better. Honda used a similar design on some of their engines in the past. The antifoulers are available at some full line auto parts stores for less that $3.00 each. If your "L" has very large plugs, they may be harder to find, or you might need a bushing."
Jeremy
04-13-2002 23:09:55
I've never seen the anti-foul adapters in use, but always figured they were a band-aid cure.
Are the plugs in your tractor fouling from oil or a rich condition? If just a rich condition, a carb adjustment should take care of it. If it's an oil problem, going a step or two hotter in the plug range might help.
