Loose 70d fly wheel
harry in GA
10-16-2003 19:22:47
Recently someone refered to shims---to tighten up the flywheel/crankshaft. Who sells them, will they work long term,pro s & con s etc---thanks HIG
F-I-T
10-16-2003 19:55:13
 Re: Loose 70d fly wheel in reply to harry in GA, 10-16-2003 19:22:47
Harry:
On a diesel, I don't think you will be able to get by with shims. That old '70'D will hamnmer on the best of splines, and I think you will be wasting your time.
How loose is it? Could it be that you can clean both surfaces really well, and then install the flywheel to the correct endplay, and then torque it down with new Grade 8 bolts with hardened washers and tall nuts and get it to hold? If not, you might be in the market for a new taper-lock flywheel adapter.
Sorry,
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
