70D Project: A little more progress...
Frank-in-Tallahassee
04-13-2002 17:13:26
third party image
Well,
At first glimpse, it might not appear that much work has taken place.
But...if you look over the engine, you will see that I have been able to remove the Right rear wheel and rim (one of the wedges had some threads stripped, might look for another). The pumps, injectors, and fuel transfer pump are installed and timed. Upper water pipe, intake manifold, governor, fanshaft, p/s pump and fan assembly are on, p/s pipe and new pressure hose installed, as well as the throtle linkage to the pump rack.
I plan on installing the pony as soon as I can rig a way to spot check the oil pressure on it. Since it has no permanent gauge, I'd like to see the indicated pressure at least once.
Then the aircleaner and fuel tank...and then...
It's getting close, now...
70D // 855
Mikey G
04-13-2002 18:00:39
 Re: 70D Project: A little more progress... in reply to Frank-in-Tallahassee, 04-13-2002 17:13:26
Looks great Frank. Keep up The good work .Thank you for all the good input to this group You ,Clooney,Ol John T and Gman are the best.
Mikey G
