Model 50 generator
bart
04-13-2002 14:13:12
Do i hook the gen right to batery or does it go to switch first ????? ?
Clooney
04-13-2002 16:52:32
 Re: model 50 generator in reply to bart , 04-13-2002 14:13:12
Bart, does the generator have a regulator on it?
~Is the regulator hooked up to the (F) & (A) posts on the generator?
~If it has a regulator does the regulator have 3 or 4 terminals on it?
~What model 50 do you have?
~We will need to know the above to guide you on installation.
bart
04-14-2002 08:40:19
 Re: Re: model 50 generator in reply to Clooney, 04-13-2002 16:52:32
Clooney it does not appear to have a regulator all i see is a post marked a nad one marked f. It is a 1954 model 50 ser#5016089
Clooney
04-14-2002 10:46:14
 Re: Re: Re: model 50 generator in reply to bart, 04-14-2002 08:40:19
Bart, you will need a regulator for the generator to operate. ~Depending on how your tractor is set up, positive ground or negative ground, (it was positive ground from the factory) you will need a regulator rated for either that ground, or both + & - grounds. ~Then it will have to be installed on the generator & wired to the generator & ammeter.
~Regulator wiring is as follows: (BAT) terminal goes to NON-battery side of ammeter,,,(GEN) terminal goes to (A) post on generator,,,(F) terminal goes to (F) post on generator. After installation you must polarize the generator by momentarily hooking a jumper wire from (BAT) to (GEN) terminals on the regulator, after a spark remove the jumper wire, it is then polarized.
Frank-in-Tallahassee
04-13-2002 16:52:03
Bart:
You can view a wiring diagram of your 50 at Deere Hunters website.
70D // 855
