630 starter won't disengage
Texas630
10-16-2003 19:05:22
I have just obtained a 630, and it will start after a couple of s but the starter stays engaged and keeps spinning. A few days ago, when I tried to it it wouldn't spin, so I looked behind the switch and found a loose wire. I connected it to the nearest bare wire and the starter turns again. Could this be part of my problem?
ET
10-17-2003 07:03:14
 Re: 630 starter won't disengage in reply to Texas630, 10-16-2003 19:05:22
Look at the bendix end of the starter. There should be a stop ring that clips over a round snap ring on the amature shaft. The bendix comes up against the stop ring when it engages. If that ring is broke off the starter won't disengauge.
ChuckW
10-17-2003 05:13:44
sounds like the teeth are messed up on your ring gear....I would take a small grinder and clean up the teeth and cut the engaging angle back on the teeth. You may want to check the bendix/drive gear also....If power is broken the return spring in the solenoid should disengage the starter....
Clooney
10-17-2003 03:37:41
Texas630, that loose wire could easily have been the reason it wouldn't crank but unless that wire was touching a powered wire when it was loose it isn't the reason the starter stayed engaged.
~You might want to give it some time to see if your starting problem was corrected by you re-installing that wire. If your problem comes back you will have to trace the starting system wiring & verify the starter is wired correctly & none of the wires are touching each other or contacting an adjoining switch or solenoid terminal.
~I have some wire harness routing & wire schematics for your 630 so let me know if you need something in that area. Be careful of some of the on-line wire diagrams as most of those cover multiple tractor models & show wires that either you don�t have, or don�t show circuits that you do have�
[email protected]
R. Marg
10-16-2003 19:37:02
yes it could be a lot of the old tractors grounded the thing to get the starter to go in stead of putting it to hot sort of back words wireing
