720 injector sleeve coolant leak
Guy
04-12-2002 08:58:35
First, I want to say thanks for the dealer recommendations in southeast Michigan.
I got the sleeves out last night, made a puller by grinding slots in the thread of a piece of water pipe instead of the tap suggested in the manual. Worked for a lot less $$.
It's a little work, and I still don't know the cost, but if you have a similar system and the o-rings are old, I would recommend doing it.
I hate to think of the results of a slow glycol leak into the oil if I had not found the leak before I put it together.
