JD A bad runnin'
IH puller
04-11-2002 19:02:15
our JD A act like it needs plugs. lacks power smokes hard starts and back fires occasonly on a major decrease in throttle in road gear, we pulled the plugs but there clean. any suggestions?
John
04-12-2002 08:45:56
 Re: JD A bad runnin' in reply to IH puller, 04-11-2002 19:02:15
I had a similar hard starting problem with a Ford flathead engine..changed the condensor. Starts easy now, no way I know of to check a condensor.
Deere Puller
04-12-2002 07:28:38
Does it blue or black smoke? More info needed to really provide meaningful help.
RayP(MI)
04-12-2002 05:31:42
Could well be the plugs. Would be pretty cheap to replace them. While you're at it, check the plug wires for cracks, etc. and the magneto cover for cracks. Wouldn't hurt to do a full ignition tuneup, now that you mention it!
Know it all
04-11-2002 20:10:00
I would first take one of yere there Farming-all Engines, cut it in half,weld up thy water leaks,then replace yere poppen john engine with that, I think you will be pleased with the smooth running low torque machine you end up with.
