720 Hydraulic problem
John W.
04-11-2002 17:27:34
Hi Clooney and members, I have duel hydraulics on my 720. I found the adjusting screw. I removed the cap and found instead of a slotted screw. I found a screw with a threaded base, a narrow neck about one inch long with a disk shape head. Very stange. How do I adjust that. Have any of you seen this before? I hope I described it correctly. Thanks in advance. John
Clooney
04-11-2002 18:02:30
 Re: 720 Hydraulic problem in reply to John W., 04-11-2002 17:27:34
John, did the screw come out with the cap or did it stay in the adapter housing?
~I haven't adjusted a duel hyd in many years but don't remember it being that much different. I think the screw has a little ball type end on a short thin section (that end goes into the adapter).. It kind of sounds like the screw came out with the cap nut, if so remove the screw from the nut & install it in the adapter, ball end first then tighten until snug, then re-install the cap nut.
