2510 injectors
kms
04-11-2002 17:01:14
My 2510 needed new valve guides and I had the head checked, it had a loss of power and was blowing oil out the #3 cylinder ex. put back together without the manifold and started it to check for leaks.found the #4 cylinder is running cold. everything seems ok no leaks, system seems to be bled. can I clean this injector or adjust it or is this something I need to take to the John Deere dealer? thanks for any info ----kms
G-MAN
04-11-2002 17:12:01
 Re: 2510 injectors in reply to kms, 04-11-2002 17:01:14
I would crack the line loose at the suspected injector with the engine running, and verify that you are getting good fuel to it. Just loosen the nut a half turn, and you should get good, strong and regular spurts of fuel from the fitting. If this proves to be the case, I would remove the nozzle and take it in to be tested. Your JD dealer or any injection shop should have the specs, or if you would happen to have a pop tester, you could check it yourself. Even if there were some air in the lines, it should clear itself out in a short time. Sounds to me like you probably have a faulty nozzle. Also consider replacing them all if that one proves to be bad, as they likely all have the same hours on them, and the others probably aren't performing up to snuff, either. Opening pressure should be 2550 to 2650 psi. It looks like your tractor uses Stanadyne pencil nozzles, and those things are usually dirt cheap as far as nozzle go, so you should be able to get new or rebuilt ones real reasonably, like maybe about $60 a piece. This isn't too bad, especially after you've just done the cylinder head. Hope this is of help to you.
