Ideas on replacement hydraulic tubing assemblies
F-I-T...long po
12-10-2003 13:56:25
Awhile back "Upperppinecreek" responded to a post regarding a possibly unavailable diesel injector line. He said his company often built individual lines for customers who could not get an original.
I'm going to make a composite of the posts here as they took place some time ago. I think there might be a real need with some of you if you have rusted out PowR-Trol lines, missing oil pump lines, broken/missing hydraulic lines (my case), or need a broken diesel fuel injection line replaced. I thought it might make for an interesting thread.
Posted by F-I-T:
Hey Upperppinecreek:
Back on the post for the fellow having trouble finding a diesel injector line for his 2010, you mentioned a service at some hydraulic shops called "tubes@hoses". I'm sure I'm not alone in saying that some of the toughest items to find when fixing up an old tractor are hydraulic tubes, fuel lines, oil lines, etc. Could you tell us more about the service you offer? Again, what kind of dealer are we looking for? If a person doesn't have a dealer nearby, do you accept mail orders? Could I send you the end fittings I need to match, and then say a 1/4" rod bent into the correct shape for a pattern? What sizes of tubes can you provide? For example, I'm thinking of all of those tubes like on my '70' Diesel for the PowR-Trol pump that are steel and no longer available, or the Pony Motor coolant tubes that are also NLA and almost impossible to find. You just might have a side business you didn't know was there! Frank
Upperppinecreek Posted 12-08-2003 at 06:23:38 [Reply] [No Email] 12.173.110.153-6839
Sorry for not answering sooner but was traveling out of town on business. "Tubes n' Hoses" would be listed in the Yellow Pages in your area under �Hydraulic Equipment Repair� if there is one in your area. Yes, we do accept mail order repairs and if you sent fittings you wanted with a pattern or just the old assembly we would fabricate a new one. Basically we can duplicate almost any tube or tube/hose assembly. Our equipment will do tubes up to 1 1/4 inches O.D., hoses up to 2 inches I.D., and pressures up to 6000psi, depending on application. We accept MC/VISA for payment. The contact would be Dale Appleman, Service Mgr. at Field-Tec Services, Inc, 2040 Lime Bluff Rd, Muncy, Pa 17756. Phone (570)546-2607/Fax (570)546-2551 or e-mail at [email protected]. We will be glad to help anyone with the tube problem, appreciate your input, maybe I should run an ad in some of the mags. Thanks
Mark
12-10-2003 15:30:05
 Re: Ideas on replacement hydraulic tubing assembli in reply to F-I-T...long post, 12-10-2003 13:56:25
Never had any trouble reading your informative posts here. Thanks for spreading your knowledge.
Wayne in Tn.
12-10-2003 14:06:30
Frank, you must have a "BIG" computer, your posts run halfway off my screen and I can only read one sentence at a time, by scrolling back and forth.?????
F-I-T
12-10-2003 14:09:36
 Re: Re: Ideas on replacement hydraulic tubing asse in reply to Wayne in Tn., 12-10-2003 14:06:30
WAyne:
I have no idea why, it appears fine to me. What resolution do you have your display set to?
(Control Panel->Display->Settings)
Wayne in Tn.
12-10-2003 14:18:14
 Re: Re: Re: Ideas on replacement hydraulic tubing in reply to F-I-T, 12-10-2003 14:09:36
Frank, you just sent me to something I had never seen before (self taught on the PC) But the little slide bar is set on "less" 640x840 pixels. But everyone else's posts show normal size on my screen, its just yours that is too big.???
F-I-T
12-10-2003 14:22:35
 Re: Re: Re: Re: Ideas on replacement hydraulic tub in reply to Wayne in Tn., 12-10-2003 14:18:14
Okay, now I set my resolution on 800x600 and I'll type in a long sentence. See if you have to scroll to see this...
Otherwise, depending on the resolution of your monitor, I think you could increase your screen resolution and see more of all screens.
CPeter
12-10-2003 16:31:12
 Re: Re: Re: Re: Re: Ideas on replacement hydraulic in reply to F-I-T, 12-10-2003 14:22:35
Frank, I use 1024x768 and still have the problem with SOME of the threads going long on the screen. It is not consistant with any particular person, but is consistant for all posts in a thread that do go long. I don't think that in this case it is screen resolution that is causing the problem.
CPeter
Wayne in Tn.
12-10-2003 17:03:06
 Re: Re: Re: Re: Re: Re: Ideas on replacement hydra in reply to CPeter, 12-10-2003 16:31:12
You are right C Peter, it makes everyones reply long in the threads. But if I go to another post, it is back the right size. Frank, yes yours was still long after your reply. I think you will have to make a new post to see any difference???
F-I-T
12-10-2003 17:21:51
 Re: Re: Re: Re: Re: Re: Re: Ideas on replacement h in reply to Wayne in Tn., 12-10-2003 17:03:06
Wayne:
What happens if you change your scrreen resolution to 1024x768 pixels? If your monitor will support, I bet all your viewing problems will go away.
Just remember where it was so you can set it back if the print is too small for you.
Now this is short message. It should not go long on your screen if long posts matter.
Screen resolution is all I can think of. After that, I don't know.
Frank
