3020 guages
gdog
04-11-2002 11:41:50
What are the four guages the 3020 has on the dash with a powershift transmission.
JDJIM
04-12-2002 17:50:01
 Re: 3020 guages in reply to gdog, 04-11-2002 11:41:50
Powershift pre '69 has four gauges , fuel , engine coolant temp , trans temp and trans pressure .
John in Md.
04-11-2002 17:40:07
gdog,I just walked out and checked.On the left there are three guages,fuel on top,trans temp on lower left,coolant temp on lower right.In the center is the tac.On the right there are four warning lights,on top is the high beam indicator,below on left is generator,then air filter,then engine oil.
That's what's on the dash of 1972 3020 Powershift,hope that answers your question.John in Md.
G-MAN
04-11-2002 16:39:27
I could be wrong, but I think there are only three. Fuel level, coolant temp, and trans pressure. The only other one would be the speed-hour meter (tach). The only other two monitored functions are generator and oil pressure - and they both have indicator lights - the two red lights that come on when the key switch is on and the engine is off - a lot of times you can't see the voltage and oil pressure symbols in them anymore.
