JD400 Serial Number
Cosmo
04-11-2002 08:38:30
Hello,
I have a JD400 wheel loader w/backhoe. I am not sure of the year. Can I tell from the serial number. It is 060161T type is 15w3d. Thanks
Cosmo
Brandon
04-11-2002 09:24:24
 Re: JD400 Serial Number in reply to Cosmo, 04-11-2002 08:38:30
You have a 1968 JD400, with diesel engine and reverser transmission. Take a look at the tag again, the first letter for the type should be T, instead of 1.
T5W3D 060161T
Good luck,
Brandon
Cosmo
04-12-2002 05:25:33
 Re: Re: JD400 Serial Number in reply to Brandon, 04-11-2002 09:24:24
Brandon,
What part of the serial number indicates the year?
How did you no it was made in 1968?
Brandon
04-12-2002 09:16:35
 Re: Re: Re: JD400 Serial Number in reply to Cosmo, 04-12-2002 05:25:33
This gave me the year- 060161
I just realized I made a mistake. It is a 1967 tractor, NOT 1968. Sorry.
It doesn't give the year directly. First, you have to realize that the JD400 was based on a agricultural 2020, and the two used the same serial numbers.
So you have to find a list of the year serial number breaks for the 2020.
According to what I have,
42721-65175 were built in 1967. Yours falls in between these two numbers, making it a 1967 model.
The first part of your number: T5W3D It tells what engine and transmission were on the tractor, and it says that the tractor is a JD400 instead of a 2020. If you want, I can explain this, although, it is a bit complicated.
Good luck,
Brandon
