JD BW pig to start
TimW
04-11-2002 08:16:44
Help !!
My 1943 JD BW is proving to be a pig to start on the flywheel ( it will occasionally, is OK on a pull and runs perfectly once started)
It has a good spark at the mag, new gas in the tank, new plugs (NGK A8�s all I can find in the UK). It does fire once or twice to fool you in to thinking it�s going to go but generally doesn�t and backfires from the R/H cylinder occasionally whilst trying to start it. Things I am not sure about, the mag is not the original being a Wico series �A� rather than I guess a �C� would this affect it ? Dose the position of the idle and run jets affect the starting ? Someone suggested that the flywheel may have been put on one spline out but I have tried timing forward one spline but it doesn�t appear to make any difference!
Exhausted
phil
04-11-2002 10:36:46
 Re: JD BW pig to start in reply to TimW, 04-11-2002 08:16:44
Tim, another thing to check is the impulse spring in the mag - it provides the spark boost at cranking speed.
ChuckW
04-11-2002 10:24:16
for what it's worth, many folks open the throttle on wide position and it is next to impossible to obtain enough charge of gas to start on wide open position. I alway am sure just to crack the throttle....this works best.
John T
04-11-2002 09:15:21
Tim, I would start with checking the mags initial static timing since you say she at times backfires. (Remove the plugs and time as follows) With the left number one cyl at TDC on its compression stroke, the mag should snap over and fire (left cylinder) when the Left Hand Impulse timing mark on the flywheel passes the timing mark at 3:00 o clock on the side of teh tractor next to (towards drivers side) the flywheel. If not, loosen and rotate the mag CW to retard, CCW to advance until u get that setting. Hard to start hand crank mag tractors which run fine once started, can be a sign of a weak spring and possibly bad points also. I assume the points are set at 0.015 and not pitted or corroded ?? because that can be a problem also. Check the timing and points and celan ur plugs and [post back Also YESSSSS an improper adjusted carb can be a contributing factor. If the timing dont help post and we will guide you through carb adjustment. Also, let us know if the plugs are gas wet, or dark flat black sooty looking, or wet shiny black looking??? Good luck Ol John T
