1935 D Cyl to case gasket
Marty Z
04-11-2002 00:07:13
I have a new gasket for the Cyl to case meeting. Is it OK to use a High temp RTV to help it seal or should use something else?
Marty Z
Clooney
04-11-2002 03:25:46
 Re: 1935 D Cyl to case gasket in reply to Marty Z, 04-11-2002 00:07:13
Marty, there are a lot of opinions on the type of sealant to use. Seems like almost everybody has something they like better than others due to experience.
~I personally use LocTite 518 gasket reinforcement/sealant for gaskets that won't be removed for years & aviation grade Permatex #3 for gaskets that might need to be tightened or removed in the near future.
~I personally don't like or use silicone due to the fact that once it starts leaking (& it usually eventually does) you can't stop the leak with a tightening of the bolts..... ..
