John Deere A floods easy
DJ
04-10-2002 17:02:54
My '47A floods very easily. If I don't pull the choke at all, it won't pop. If I pull it out and right back in, it floods. I let it set a few hours, and put in dry plugs, and then it usually starts. How do I increase the spark? It has a good coil and a Delco distributor, just gone over. The plug wires seem to be fine.
DJ
04-10-2002 19:19:25
 Re: John Deere A floods easy in reply to DJ, 04-10-2002 17:02:54
Thanks guys, I'll do it!! DJ
A Man
04-10-2002 18:50:34
Rebuild the carb that is your problem and chech the float make sure it is gool and not set wrong and be sure to clean all the passages in the carb your carb on an A can cause a lot of problem and i had to put an inline filter on mine to stop all my problems let me know what happen i wish someone would have help me when i was having this problem
Ray
04-10-2002 17:17:38
Your working on the wrong thing,the carb is the
trouble.Have someone who knows what he's doing
rebuild it.I messed around for 2 years had two
different garages rebuild it,and it ran the same.
Took it to a carb shop,and now it runs great.
