Clooney
04-10-2002 04:06:11
Re: Re: Re: John Deere 730 Wiring Troubles in reply to Colt Edin, 04-09-2002 20:13:00
Colt, your tractor isn't really a positive ground, it is both a positive & negative ground depending on which battery & light you are talking about. ~The starter, generator & REGULATOR are each isolated from ground (or at least they should be)so neither uses the tractor frame for ground when in use. THE ONLY TIME YOUR SYSTEM IS 24 VOLTS is during starting & battery charging, the rest of the time it has 2 separate 12 volt systems that each run 1/2 the electrical accessories. ~You should not see 24 volts if measuring between either ignition switch fed wire & the tractor frame. You should see 12 volts on either feed wire TO FRAME GROUND, & see 24 volts ONLY IF MEASURED BETWEEN THE 2 FEED WIRES. ~Using 2 12 volt batteries in series you should have the positive post wired to the return side of the starter, generator & regulator with a wire running to the ignition switch (it was the (HD) terminal on the 720 but I'm not sure on the 730 with 4 headlamps, & the negative post should be wired to the starter solenoid & regulator (BAT) terminal with a wire running from the regulator (BAT) terminal to the second ignition switch feed terminal (it was the (A) terminal on the 720 but again I'M not sure on the 730 with 4 lamp system. Here comes the good part (read important part) the short cable that ties the 2 batteries together (the one between the batteries) MUST ALSO GO TO TRACTOR FRAME GROUND as that cable being grounded is what supplies frame ground to both (SEPERATE) 12 volt systems on the tractor. ~One side (the return side) is a 12 volt negative ground & the other side (the side hooked to the (BAT) terminal on the regulator, is positive ground & BOTH sides of the separate 12 volt systems USE THE CENTER BATTERY GROUND cable as the frame ground for their side of the system. ~This probably doesn't make any sense to you now, but will after you look at the wire diagram & actually figure out power flow from the switch through the lights & accessories to FRAME GROUND. ~Once again, the 24 volts is isolated from frame ground & only used for the starter & generator which is ISOLATED from frame ground. ~OR to look at it another way... Your tractor has 3 separate battery systems that all just use the same batteries for power,,,A positive ground 12 volt system for 1/2 the lights & accessories,,, A negative ground 12 volt system to power the other 1/2 of the lights & accessories & AN ISOLATED GROUND 24 volt system for starting & charging. If wired correctly they shouldn't backfeed or contaminate each other... ~Think of your system as a house wiring system, you have 220 volts to the main breaker powering 2 110 sides of your breaker box, with a neutral bar (your center battery ground), if you hook between the two 110 bars you have 220 volts, if you hook between either 110 bar & the neutral bar you have 110 volts. ~I know this is confusing, so if you still don't understand the complete system, post back with questions as it will be easier to answer questions than explain the system. If you want I will try to draw a simple wire system showing the separate 12, 12, 24 & how they interface..... ..... ..
