730 Diesel battery box
Brad
04-09-2002 15:35:52
I just got a 730 D electric start, the battery box sticks out over the floor board enough so it makes it tight to get on the thing. Im thinking maybe the box is off a different tractor? or is this normal?
steve
04-10-2002 17:19:50
 Re: 730 Diesel battery box in reply to Brad, 04-09-2002 15:35:52
yes they are a pain
I moved mine back about 4 inches
to do so, remove batteries,unbolt 3
bolts from 3 point lift lever,4 bolts
that hold box to tractor,lift box off.
carefully mark and cut hole in bottom
of box for hydro filler,it will be close to back edge of box.drill 3 new holes for 3 point
and put back on. the holes are already in bottom
of box. do it neatly and you will be only one who knows,exept correct police.
steve
04-10-2002 17:18:51
yes they are a pain
Marty G
04-10-2002 15:18:43
I have a 730D and yes it is the way they were built.A pain ! yes worth it ! YES .
Larry
04-10-2002 12:23:59
The 730 ES battery boxes are a fair bit larger. If the gear shift lever is in the down position it is difficult to get your leg between the shift knob and the battery box and shock absorber. I am a good sized guy and I just have to always move the shifter up. The enjoyment of running the tractor is worth some minor aggravation.
Joe
04-09-2002 18:38:06
without a picture its hard to tell, the boxes are pretty big so im not sure unless i see it.
