Model 50 power shaft
bart
04-09-2002 11:59:13
I am haveing trouble engaging the pto (power shaft) Its the live type (runs of engine, Has seperate clutch) Tryed bumping the starter had no luck. am going to try to turn shaft with pipe wrench. (trying to get gears to mesh) Any other ideas can i see linkage if i take off the shifter housing????
GWH
04-09-2002 18:46:09
 Re: model 50 power shaft in reply to bart, 04-09-2002 11:59:13
I hope you get your problem sorted out. Just wanted say that my 1955 model 50 left the factory without a pto period so i don't have that problem considering a pto was standard equipment at that time. I know why - lets see if some of the veterans of the board know?
alcgar
04-09-2002 18:29:38
Hey Bart, I told you these folks would help you out. Your pal in Pownal, Al
bart
04-13-2002 14:12:03
 Re: Re: model 50 power shaft in reply to alcgar, 04-09-2002 18:29:38
thanks everyone for your help it was just a little jammed and i was pushing it the wrong way
Tye
04-09-2002 12:18:42
Check to see if the little lever right next to the gear shifter is engaged.
Tye
04-09-2002 12:18:18
bart
04-09-2002 15:01:08
 Re: Re: model 50 power shaft in reply to Tye , 04-09-2002 12:18:18
stupid ??? witch way do i move the lever to the right or left to engage
Frank-in-Tallahassee
04-09-2002 15:15:30
 Re: Re: Re: model 50 power shaft in reply to bart, 04-09-2002 15:01:08
Bart:
Engaged is toward the gearshift quandrant.
70D // 855
