4020 horsepower increase
Josh
04-08-2002 19:51:05
I was wondering if you all could help me? I'm a young farmer(24)takin over the family farm and renting some ground on my own. our equipment has some age on it but I happen to thinks its the best there is. I'm running a couple of 95 deere combines, 68 and 69 models, and some 4020's. I'm wanting to play with one of them and see how much extra horse I can gain. It's a 64 model 4020 diesel with a powershift transmission. I've already purchased an M&W exhaust manifold and elbow to put a blower on it. I was wondering if there are any other things I can do to improve my horsepower and pullin power and still keep it where its a field tractor. I dont want to get too radical! Thanks for all your help in advance.....Joshua
DON
04-09-2002 13:35:02
 Re: 4020 horsepower increase in reply to Josh, 04-08-2002 19:51:05
Josh, I don't want to rain on your parade ,but take some advise from and old Mechanic. If you need more power get a bigger tractor. I have put on those M/W turbos and if you want to burn up a good tractor then this is the quickest way I know to do it. If you need more power, go find a 4320 or 4620, they were made for the hp and dont cost much either. M&W recomended 110 for 4010 and 115 for a 4020 if you want it to live. You say that you have a lot of smoke now , the turbo will clean up the smoke and the power will be abt. right.For what its worth. Don
Dan
04-08-2002 21:16:05
You may also want to get the injector pump turned up a bit with the turbo on there.
Josh
04-08-2002 22:19:40
 Re: Re: 4020 horsepower increase in reply to Dan, 04-08-2002 21:16:05
I've already did that....turnin about 105 to 110 horse naturally aspirated....really rolls the black smoke on a pull now!...thanks for the advice though.....joshua
Jim
04-08-2002 20:27:08
Try and locate a M&W oil pan for the 4020. Your tractor could use the larger oil pan for cooling purposes. Install an exhaust temp gauge so that you don't melt your tractor.
A larger radiator fan can also be installed to help cool the tractor.
Josh
04-08-2002 20:39:24
 Re: Re: 4020 horsepower increase in reply to Jim, 04-08-2002 20:27:08
not to be a pain but where can I locate an M&W oil pan at?...I never knew they were made?
JDJIM
04-08-2002 21:58:23
 Re: Re: Re: 4020 horsepower increase in reply to Josh, 04-08-2002 20:39:24
M&W made a 20qt aluminum pan and a 8 blade & shroud kit for the 4020 . Far as I know they aren't available and haven't been for quite a while . Now and then I see them in classifides and at auctions but it has been a while . Might check these classifides though I don't recall one recently .
If your 4020 is in good shape ie. COOLING SYSTEM , fuel system ,the rest of the engine , transmission pressure up to max and the rest of the powertrain you can run it 120-25hp and NO MORE for field work and it will hold together . Don't forget you are increasing hp by 25% in a 38yr old tractor . Injection pump will need to be modified also as mentioned above . It will probably have to be taken apart to get the fuel increased enough . I have a '64 Powershift with turbo , pan , fan and a few more goodies , it is not used for heavy field work , just a chore tractor , mowing , auger work baleing etc and tractor pulling . Great old tractor .
Josh
04-08-2002 22:24:13
 Re: Re: Re: Re: 4020 horsepower increase in reply to JDJIM, 04-08-2002 21:58:23
Jim, thanks a bunch for your help, now I'm on a mission to find this! mechanically this tractor is in great shape...I think it'll hold up really good with no problems. I'll try and keep ecverybody posted on mt progress if you'd like!.....Joshua
JDJIM
04-08-2002 22:35:53
 Re: Re: Re: Re: Re: 4020 horsepower increase in reply to Josh, 04-08-2002 22:24:13
Josh , keep us posted and please feel free to email me if you have any problems , JIM
Where are you located?
Josh
04-08-2002 22:41:29
 Re: Re: Re: Re: Re: Re: 4020 horsepower increase in reply to JDJIM, 04-08-2002 22:35:53
Jim, I'm located right in the middle of GOD'S country...Shelbina Missouri.....the northeast part of the state.....Joshua
Mike Aylward
04-09-2002 06:40:21
 Re: Re: Re: Re: Re: Re: Re: 4020 horsepower increase in reply to Josh, 04-08-2002 22:41:29
Josh, you are not too far from me. I live near Arbela which is close to Memphis. I have two 4020's that have run close to 130 h.p. for many years (naturally aspirated). I thought about putting a turbo on one years ago but didn't want to cut another hole in the hood to do it. There are a few "cheap and easy" things to do to your 4020 to wake it up. Email me if you have any questions. Mike
JDJIM
04-08-2002 23:02:14
I'm in north central Illinois , right on I80 in the middle of the high rent district .
Denny Frisk
04-09-2002 08:34:36
 Re: Re: Re: Re: Re: Re: Re: Re: 4020 horsepower increase in reply to JDJIM, 04-08-2002 23:02:14
Sounds about like LaSalle-Peru area Huh? Folks live just down the road.. Exit #19... I know what You mean about "High Rent"
JDJIM
04-09-2002 19:24:29
 Re: Re: Re: Re: Re: Re: Re: Re: Re: 4020 horsepower increase in reply to Denny Frisk, 04-09-2002 08:34:36
Your close , I'm about eight miles west , couple miles west of Exit 70 , south side , bordering the highway .
RHA
04-09-2002 09:32:19
Any Relation to L, G, or K Frisk in Henry Co.
Denny Frisk
04-09-2002 13:56:10
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 4020 horsepower increase in reply to RHA, 04-09-2002 09:32:19
WHAT DID THEY DO???? Uncle L is Dad's Older brother.
RHA
04-09-2002 20:15:36
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 4020 horsepower increase in reply to Denny Frisk, 04-09-2002 13:56:10
Not a thing. Grew up 1/2 mile west of L. By the way-have the pulling sled contract for the farm stock pull at the Henry Co. fair in June. I think I have dropped the hammer on JDJIM's 4020 a few times.
JDJIM
04-10-2002 04:07:24
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 4020 horsepower increase in reply to RHA, 04-09-2002 20:15:36
You and the previous owner of that sled have got us many times over the years . Are they having a FARM STOCK this year or are you talking about WCITPA's class ? Talk about a small world . JIM
RHA
04-10-2002 06:51:17
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 4020 horsepower increase in reply to JDJIM, 04-10-2002 04:07:24
ISP has the Sunday afternoon show. Farm stock classes are 7000 and 10000# Henry Co. only. I Bet you know about that game. Two ISP truck classes + two stock truck classes. 7000 ISP tractors + 7000 light limited pro smokers. I think Outlaws are running on Thursday.
Josh
04-08-2002 23:27:21
black dirt country huh?...you guys wouldnt know what to do with some of this missouri clay...how much is land renting for there?
