Clooney
Model B Gen/Reg charging at 9.2 Volts
POPPER DICK
04-08-2002 18:49:15
Clooney,
I was invited back to the generator shop with my 8 volt battery and generator. We installed my battery and generator/regulator on the machine and set her up at 9.2 volts. At the time of the testing the battery demand was 10 amps. With a digital volt meter on the battery terminals the charging voltage started at 8.6 and after 2 1/2 minutes it reached 9.2 volts. I learned a lot today on how a regulator works.
Again, thanks for all your help
Dick
Clooney
04-08-2002 18:53:52
 Re: Clooney - Model B Gen/Reg charging at 9.2 Volts in reply to POPPER DICK, 04-08-2002 18:49:15
Dick, too bad you set that voltage up. I was curious if a 3/4 charged battery would work through the cold of winter. I guess we won't know now.....
POPPER DICK
04-08-2002 19:21:08
 Re: Re: Clooney - Model B Gen/Reg charging at 9.2 Volts in reply to Clooney, 04-08-2002 18:53:52
Sorry Clooney
Thanks again for your help.
Dick
