420W Throttle won't stay at Fast Idle
Henry J
04-08-2002 17:55:27
Got tired and kinda embarassed holding the throttle wide open on the 420W with a bungie cord. While I was at I bought the spring that holds the tension on the thrust washer and the cork washers. When compared to the old spring the new one was about 1/2 inch longer (more tension now). Thought I would let you all know that those ole springs may be weak after 40 some years and be 1/2 of the culprit of the throttle not holding its position. Dad gum it, I did not have the right size roll pin to pin it back in tonight, but am sure that the throttle should stay on the fire wall now.
Don Young
04-11-2002 20:25:35
 Re: 420W Throttle won't stay at Fast Idle in reply to Henry J, 04-08-2002 17:55:27
If it still won't, the booster spring at the front end of the rod where the governor rod attaches may be weak too.
