What does a Flywheel weigh on a styled D
Jon
04-08-2002 09:08:54
What does a D flywheel weigh the number is AD852R. It is a hand start one. And is there a differance in the weight of a electric start flywheel to hand start. The number on it is AD2331R. Has anyone ever seen an AD1903R flywheel off a 113 engine. It was 270 lbs. Thanks for any info.
Deere Tom
04-08-2002 16:02:00
 Re: What does a Flywheel weigh on a styled D in reply to Jon, 04-08-2002 09:08:54
Take it from some body that took one off by hand. Do not!!,that flywheel is every bit of 145#
tsoukjr
04-08-2002 14:44:25
Im guessing LLLLL Looooo ooottttt ttttt tsssss sss!!!!! !!!!! of pounds
Bob-Wyo
04-08-2002 10:41:51
Jon this was posted before by Dan. About the AD1903R flywheel, only seen a picture of one on W engine, quite a chunk of iron.
Hope this will help.
Bob
Posted by Dan on March 17, 2002 at 22:18:22 from (209.162.162.106):
In Reply to: Weight of Styled D Flywheel posted by cheg on March 17, 2002 at 19:17:33:
The same flywheel was used on the manuel start from 1931, Ser # 109944D. AD852R, Casting # D1970R - 145lbs. AD2331R,Casting # D3100R - 216.75lbs. the latter is for the electric start.
