John Deere 950 PTO not independant?
CND10BEST
04-08-2002 06:53:48
Everything I have read indicates that the JD 950 I just bought has an independant PTO. The gentleman I bought it from even confirmed this. It is supposed to spin even when clutch disengages drive wheels (2-stage clutch). I finally had an opportunity to hook something to the PTO and was shocked to find out the PTO disengages at the same position in clutch pedal travel as the drive wheels do. I see no external way to adjust the clutch. Did I miss something? Did I get snookered? Is there a trick or lever that I am not seeing? Help.
BB
04-08-2002 10:17:57
 Re: John Deere 950 PTO not independant? in reply to CND10BEST, 04-08-2002 06:53:48
I am thinking along the same lines as Chuck. I believe the 2 stage clutch was added in the later models (after about 1982 I think).
ChuckW
04-08-2002 08:16:27
As I recall the early models did not have live power, they added in later production runs. Might check with JD dealer to be sure. If sold as live you may have something of price to discuss with the seller. There is a possibilty that it does have and the 2nd stage is not releasing. If you really load up the mower heavy grass you could test, you probably couldn't test without heavy load.
