JD60 piston rings
Leon R
04-07-2002 20:24:32
I am in the process of reassembling my JD60 engine
and purchased the JD ring set. I notice that there is quite a difference in the style of rings ie the oil ring and bottom skirt rings are solid (not perforated like the originals) and they do not have that underlying wavy spring as the originals. Is this a new and improved ring set for these engines or do I have the wrong set? They are the correct size but the oil rings don't look like what I am used to seeing.
Will P
04-07-2002 20:50:52
 Re: JD60 piston rings in reply to Leon R, 04-07-2002 20:24:32
My B set was solid to with a bevel on the top of the oil ring. Put the bevel toward the top of the piston. the right angle should be toward the bottom of the piston. Hope this helps.
Will P
