J D model D starter switch
Steve
04-07-2002 09:02:52
I am working on several model "D"s and all the starter switches are rusted . These are a pull out switch to start the tractor. Has any one ever found a way to loosen them,or repair them? Is there any place they can be purchased new? John Deere doesn't have them.
Clooney
04-09-2002 03:11:26
 Re: J D model D starter switch in reply to Steve, 04-07-2002 09:02:52
Steve, call Agri Services (716) 937-6618 . They list a pull type starter switch for a "D" at $17.50 = $4.00 shipping..... .....
zane
04-07-2002 18:26:27
Please give more info. Are you talking about the ignition switch or starter motor contactor linkage/assembly?
Steve
04-07-2002 22:53:50
 Re: Re: J D model D starter switch in reply to zane, 04-07-2002 18:26:27
Hi Zane..... .. Sorry ,I am talking about the ignition switch on the dash which sends the power to the selinoid when you pull the knob out.
zane
04-08-2002 19:08:31
 Re: Re: Re: J D model D starter switch in reply to Steve, 04-07-2002 22:53:50
I'm not that familiar with D's, but I doubt there is a good way to repair. It's probably only a simple push/pull (open/closed) switch. Unless you're restoring w/ all original, you should be able to find a substitute in a good auto parts store. My 50 works fine with a simple toggle switch in the ignition primary circuit.
