Joihn Deere 2020 diesel
Johnny Guest
04-07-2002 09:01:20
Was driving my 2020 low RPM when it shuddered,and engine started blowing steam out the breather tube followed by the engine running roughly.Engine was not hot or even near to it.I find no trace of oil in the water or water in the oil.I suspect a head gasket,any ideas out there would be much appreciated,Thank you in advance. Johnny
John
04-07-2002 14:48:38
 Re: Joihn Deere 2020 diesel in reply to Johnny Guest, 04-07-2002 09:01:20
Could be the headgasket or a cracked/perforated cylinder liner. Most likely not the headgasket. I have done two deere engines that had bad liners that showed coolant loss but no contamination. Your most likely going to need a rebuild kit. New liners, pistons , rings, rod bearings and gaskets. As you pull the old liners out inspect the o-ring sealing area and you will most likely find eroded/corroded pits that are causing the problem.
