Early B Oil Filter
Ryan
04-06-2002 16:28:50
I found out today my B has more than one factor that accounts for no oil pressure. 1) The coupling to the oil pump drive shaft was gone. 2) The oil line that goes to the governor was rubbing on the crankshaft. 3) One of the lines that goes from the pump to filter, the bushing on the filter end was broken off. I have taken off the adjusting screw, nut, stud, and filter. I need to to take the filter head off to get the broken off portion of the bushing and maybe replace the head. I made the little tool it recommends in the book and I tried to pull the pipe/filter outlet that goes up in the middle but it seems stuck. What should I do?
Thanks for your help,
Ryan
ed b
04-06-2002 18:00:41
 Re: Early B Oil Filter in reply to Ryan, 04-06-2002 16:28:50
ryan if you are talking about the oil filter tube i had the same problem clooney recomended putting a pipe over it and it worked like a charm ed b
