Pos or Neg Ground
Al R
04-06-2002 15:54:08
I have a 1949 JD AW.It has a 12volt system. Is this a negative or positive ground system? Thanks.
Brandon
04-07-2002 06:11:05
 Re: Pos or Neg Ground in reply to Al R, 04-06-2002 15:54:08
Al;
There is some conflicting information below. The 49A came from the factory as a positive ground using 2 /6 volt batteries in series for a 12 volt system.
John T
04-06-2002 19:49:23
All 2 cylinder JD's came from the factory as Positive Ground. See which battery post is attached to the frame now to determine what you have grounded. If its been reversed (to neg grnd) and has a battery/coil igntion, be sure the - of the coil goes to ground via the distributior and its points. Ol John T
George
04-06-2002 16:47:16
Unless someone has changed it, it should have positive ground system.
richard
04-06-2002 17:55:18
 Re: Re: Pos or Neg Ground in reply to George, 04-06-2002 16:47:16
the rule is if it has a 12 volt generator and has not been messed with it will be positive ground.
Gman413
04-06-2002 17:38:25
The John Deere A is a positive ground setup.But I usualy convert them to negative ground in case I have to jump start off a newer vehicle and don't screw up something.If you convert to neg. Grd. just make sure the wire from coil to distribtor is also negative,or if you elect to use positive grd. use the positive terminal on coil to go to points,some will argue it don"t make no difference but I'm more confortable with keeping them together. Have a nice day Garland (Gman)
Dave K
04-06-2002 16:17:49
As far as I know the A's were all neg ground. Mine is.
