3010 For WTW
Brad
12-10-2003 04:57:09
I read your article and understand all the 12/24 volt, Good Information. I ran the wire between the batteries (neg. grd. to pos. grd.) and also confirmed my switch IS bad. Contacts have worn,I guess after 42 years that happens. I have power to fuel guage but I think sending unit is bad. I need a couple head lights, do you know of a source for them other than JD dealer? Thanks for The Help.
Brad
WTW
12-10-2003 07:27:28
 Re: 3010 For WTW in reply to Brad, 12-10-2003 04:57:09
Brad, Lamps are common 12 volt lamps that can be acquired at most any farm supply store. The fuel gauge and sender has become a real disaster even at a JD dealer. You may have to buy both, even though only one is bad as the gauge and sender have to be matched to work from the same amount of resistance range. Seems like they changed one where this makes you have to buy the other to make it work. One thing I know they changed for sure is the new gauges are polarity sensitive. So if you are going to leave your tractor 24 volt you will have to buy the fuel gauge and sender for a 24 volt application which the fuel gauge circuit is 12 pos. ground. As that what the fuel gauge circuit is on the 24 volt systems. If the tractor is converted to a 12 volt system with and alternator then the fuel gauge and sender is different for a 12 volt neg. ground system. What really sucks about all this is the old (original gauge and sender on the 24 volt system tractors would work either way but now the new replacement parts will not.
Farmer Jack
12-10-2003 09:44:01
 Re: Re: 3010 For WTW in reply to WTW, 12-10-2003 07:27:28
Hi Dave! Thanks for letting Marv borrow your splitting stand for my 4010D. Just talked to Marv today to find out he bought a new ranch. he and I work together.
Finally figured out the connection between the two of you.
WTW
12-10-2003 12:27:27
 Re: Re: Re: 3010 For WTW in reply to Farmer Jack, 12-10-2003 09:44:01
Nice to Meet You Jack!, Didn't know little brother was looking for more property. How many acres did he buy? Does it have buildings and where at? Hope he didn't splurge like one of his many older brothers did and buy 80 acres of prime Iowa farm ground. I bet he didn't. It will take a few years and a lifetime to pay for it. Farming it won't pay for it either. We keep them splitting stand pretty busy usually someone's tractor on them most the time. Later, Dave W.
